Re: How to start your outboard
What kind of motor?<br /><br />If its a magneto ignition the most common key switch failure is for the switch to ground out. So even if you have the key "On" the ignition circuit is grounded so the motor has no spark. You have to eleminate the kill circuit and then you can jump the solenoid. The downside is theres no way to shut the motor off unless you flood it. Which may be harder than it sounds.
