How to take out rounded drain plug on force 85? Is there a way to drain without taking it out? Like pumping out the fluid maybe?
jimmbo
You could take out the Bolts(#6), and pull the Bearing Carrier out
Most folks use an impact driver with " drag link " socket .----The kind you hit with a hammer.----Use a small center puck and hammer.----It will spin out.
I do not like those.----But use a pointy punch and hammer and you can get it to turn.
tg3690
Could maybe use an extractor a little larger than the stripped out hole, tap it in, twist it out. Corrosion shouldn't be an issue, being a lube plug.
