FreeBeeTony
- May 15, 2002
- 3,995
I am still not satisfied with the power in my '78 20' Grady with an IL6 165 Mercruiser. I know it's not going to be a speed boat.....but in order to achieve WOT of 3900RPM's I can only turn a 15" prop. I thought the engine would have been a bit stronger........I completely rebuilt it last year: bored out 0.030, new pistons/rings, bearngs, oil/water/fuel pump, new lifters, recond head/valves, new alt, rebuilt carb. The block is a '67. I used the existing crank and cam. Is it possible the cam is worn and I am loosing power due to this? Is there an aftermarket cam I could install and get more power? It runs very well.........would just like to get more power!!! w/o adding cylinders....
