how to tell if dt225 is burning right amout of oil
99yam40
mark, measure, and keep track of how much oil and fuel you put into the motor.
Do not know about a zuk but Yamaha manual has a procedure for measuring the output of oil while running on premix.
So many CCs over a measured amount on time at a certain RPM
Lower RPMs less oil is needed
higher RPMs it needs more
billdor
thank you for the advicethe plugs are new so i will check them and mark the tank before i go out this weekend
