How to tell mercury 40 hp prop size
younggun
I have a 1978 mercury 40 hp and don't know what size it is. There is 1736 stamped on the outside and 48-7313-1 stamped on the back inside on the hub. Any idea what size this is?
steelespike
Re: How to tell mercury 40 hp prop size
Are you referring to the area under the prop nut? Usually the 48- number ends in the pitch is there another digit after the 1?
probably a 1,2 or 3
younggun
It's hard to see but I think there is a 4 after the 1
younggun
And I didn't see anything under the prop nut. The numbers were on the back side of the hub
steelespike
Is the motor on a light boat not carrying much load?A 14 has only 3 props bigger.
jestor68
A Mercury black Max # 48-73138A40-14P is a 10-1/4 X 14 pitch that fits a 40 hp motor.
The current # would be QA2082X for the same prop.
It can be found in the prop section.
