How to test Alpha One Gen 2 Trim rams
jwadle
Hi all,
I had a leak in one of the lines of my trim rams. I bought the new lines and while trying to replace them, one of the bolts on the ram was frozen. So I took them both off to work on them on the bench.. I got the bolt off without an issue, but I then tried to push in on the ram it self (to see if it would move in and out), and it did not move. So I did a quick search on google and found a video of someone easily pushing it in and out. Now the rams did work before, but I also know that hydraulic force is MUCH higher than I could push, so if it was seized(ish) it would overcome that. So I went ahead and bought a new pair as I did not want to put too much stress on the outdrive or other components. So I got the new ones yesterday, and guess what I can not push those in either.. Pretty sure they are not bad.. So I guess my question is, did I just waset my money on buying new rams for nothing?
Thanks for your help as always.
Bt Doctur
most cases the end cap causes the problem due to corrosion ,make the O ring grip a lot tighter.
Alumarine
On the new rams are the plugs still in the line ports?
If so, you won't be able to move the piston rods in and out.
jwadle
If you mean the lines themselves, yes they were off the old ones, but stupidly I did not remove plugs them from the new ones.. bet you that was it.. phew, would hate to have to explain to my wife that I spent money on parts I really did not need.....again.. LOL
