Re: How to test if motor is charging battery?
I seem to see no change, or even a slight bit less voltage (around 12.5 V) when the motor is running, whereas it was at 12.7 before and after the running.
I hooked up a disconnect terminal that I could switch off to isolate the motor hotwire from the battery after cranking it up. I took a read of the engine side of the hotwire and the ground terminal, and the wild floating V meter reads like there is no voltage.
I think it is safe to conclude the motor is not charging the battery. (At purchase, the lights and bilge pump were mis-wired at the dealer and all sorts of funny things happened until I simplified them.) And mabe related to this, the stator went out at the dock when the motor was only 3 yrs old and the dealer put in another, and I have always had a strong hunch that it has not been charging since then - for a decade!
We seldom use it for more than a few hours, and not too many stop/starts when we do run, so we have not been stranded.
Is it OK to run the motor knowing that it is not charging the starter battery? Is the battery needed for anything after startup?
What part is likely broken, and how do you access it?
All this time...
