How to test Polyester Resin?
SynPDX
435 Standard Polyester Resin
Says shelf life is 3 months.... I've had mine for around 6-8 months.
The website (US Composites) says that this time may be extended if the container was never opened, and temperatures were good, etc.
So, my question:
I have this five gallon jug, never opened, it's been in my garage (Oregon), no extreme cold/heat.... What type of testing can I do to see if this resin is still usable? I've never laid fiberglass before, openly admit I have lots to learn...
I have the hardener, copped glass, silica, everything I need to make peanut butter... If I were to make a small sample, how long should it take to harden, etc? Better yet, if I were to mix up a small batch, what would I look for to tell if the resin has gone bad?
Thanks for the help ahead of time!
Woodonglass
Mix up 150 cc or resin and 1,5 cc of hardener wait 20-25 mins if it kicks off and hardens you're good to go. I'm bettin you are.'​
fhhuber
Yep... mix some.
If the can was well sealed I've seen it be good beyond 5 years.
I got 5 gal of free resin from a shop because it was outdated and the shop had to get rid of it.
