How to test the stator coil???? No spark on my Suzuki DT150
thecow18
Does anyone know how to test a stator coil to determine if it is working or not? My starboard engine currently does not want to start. I am not getting any spark.
I had the same issue last year with my port engine and it turned out to be the neutral switch after wasting four trips and a month of frustration taking it to Gates Marina and spending almost a grand there and they still could not fixed the problem and they almost got me to spend another 2k for a new CPU. I posted an ad on multiple fish forums and someone suggested the neutral switch and that was the solution to the problem. Never going back to Gates Marina in Deale again.
So now I am returning to the fish forums again to see if anyone can help me with this issue. I already checked the neutral switch and it checked OK. Thanks for your help.....
99yam40
Re: How to test the stator coil???? No spark on my Suzuki DT150
Do you have a repair manual for that motor? It should give the steps and equipment needed for testing the ignition system. What year is your motor, the serial # will give that info so post it, and it makes a difference because the systems are different on different years. I have a friend with some parts and a manual he does not need anymore if it is the correct year.
thecow18
2000 Suzuki DT150
99yam40
what is the serial #?
I think his motor was a 1997, but the manual just came from Browns point and I think it is for all year models.
Do not know if any of the parts will interchange, but if you PM me I will forward the info to him and see if you and him are willing to work something out
