Re: how to test thremoswitch
I found this info related to my horn & Thermostat switch problem. About mid way the info at the address below or run a search on wickware.
My horn?s ground is coming from the switch (if I?m not confused, the orange wire). If I ground the orange wire at the switch to the engine (as over heating will do) with my stitch on, my horn will sound. My horn will also sound if I press my horn button, which grounds the horn.
http://forums.iboats.com/showthread.php?t=378806&highlight=wickware
Good Luck!
JOW
Re: I fired-up my 1970 Chrysler 35HP for 2010 check-up with concerns.
Today?s Follow-up:
1970 Chrysler 35 HP. Is it common for the horn to serve as the horn and over-heating alarm? Today, I discovered a bad/fried 6v horn in a 12v system. With the new 12v horn, the horn works and grounding the thermostat?s connection sounds the horn. When overheating the thermostat circuit works as a ground to the horn. I ran the engine 5 minutes (in the barrel) and the horn d/n sound. Plus I could hold my hand on the engine?s cylinder area or head but I w/n want to leave it constantly over a minute or so. Does that sound about right for the combustion area surface temp?
I found a name and number locally for the cracked carb linkage. Listed as a Mercury part, Ball Socket Kit, # 828514A1 (11.50), which would save shipping. It showed that the fiber connector snaps onto the brass stud/ball. Which means I hope to find the fiber section only or a used kit at half price. I have compressed the crack with a hose clamp and I d/n see any danger if it breaks (idle home or accelerate manually). Is that cheap, economics or what (when who knows if I?ll make a fishing trip or 100 trips)?
JOW
