I barely ever run at night but the two times recently I have run at night I have noticed this problem.
Everything I turn on electrically makes my V gauge go down noticeably. If I turn the NAV lights, and guauge lights on my V gauge goes from 14-15 to 12.
If I use my trim then it drops to probably 8. (Even with nothing electrical my trim always makes my V gauge drop. Usually its from 14-15 to 12 or so.)
But what I noticed the other night is that I have a brand new spot light, and with the spot light off if I plug it in the CD player/radio will cut off then turn back on and the NAV lights will flash.
It doesnt do this when I turn the spot light on, just when I plug it in.
I have two batts hooked up. One is new in march and is a regular wet battery and the other is new in August and is a yellow top Optima.
I tried switching between thenm and using the both setting and it wtill does the same thing.
What could do this and how do I chase it down?
Thanks
Thanks
