Re: How to tune , idle 50 evenrude
Basic maintanence is to drain and refill the lower unit checking for milky looking oil and change the plugs with the correct gap, water pump if you don't know when that was changed.
If the engine is going to set unused for more than a couple weeks drain the carbs at the float bowl and as mentioned get a fuel filter on it, even a cheapy clear plastic one is good.
Again if it runs well that is really all there is to do, if you can run the engine, with water of coarse, a decarb never hurts.
Is this an electric shift?
If you plan to keep the engine I woud stronly suggest you get an OEM manual for it, that is an OMC manual, not Clymers ect, they are a little salty but pay for themselves the first time you use them, you cna get them here at iboats or look on ebay.
