Re: How to wire a momentary on/off/momentary on Toggle switch?
Let me see if I can simulate how I wired it up using a keyboard...<br /><br />This was a '6' terminal momentary on/off/momentary on switch. I only had 3 wires, 2 remotes (up and down), and a constant power.<br /><br />OK, the '+' symbol will equal the 'COMMON', or constant power source. The three '+' were all connected/jumped together, with the constant power wire coming off of the engine and connecting with the #2 terminal. The jumper wires connected to #4 and #6 as well. This means you had constant going to 2,4,6.<br /><br />the #5 terminal was left empty, '0'=nothing<br /><br />the '^' is the UP remote/trigger wire<br />the 'v' is the DOWN remote/trigger wire.<br /><br />IF I REMEMBER correctly, this is how it was. I am going off of memory (dont have the boat with me to look at it. But, I'll check it later and correct this if I messed up. <br /><br />1 [^] [+] 4<br />2 [+] [0] 5<br />3 [v] [+] 6<br /><br />Make sense? <br /><br />Thanks for all the help guys!<br />Wish me luck at the lake!<br /><br />Shawn
