? - how to wire acccessories & bilge pump with perkos
TxHorns
I'm having some electrical issues with my boat and I am going to rewire the batteries this weekend. I have 2 batteries, 2 engines and 2 perko switches. My accessories are wired to terminal buses - do I wire these buses directly to the battery? If I do that, will they lost all power when I turn the perko's off? Or should I wire them to the perkos, and if so where? Also, how do I wire my bilge pump so that it has power even when my perkos are off? Thanks for the help.
Robbabob
Re: ? - how to wire acccessories & bilge pump with perkos
Check this out.... http://forums.iboats.com/showthread.php?t=383997
I went looking for the wiring diagram for you, then realized what came up in my search :)
There are several great drawings for what you're looking for... just gotta find them.
seabob4
A drawing I have created, should serve you just fine, just run jumpers between the batt 1 and 2 studs from one to the other batt switch...
