how to wire twins into boat ?
last year i ran twin 25's one was ele. start the other was pull start .ran great loved it (my little 16 ft alum. hull realy moves).now i have ordered another ele. start kit and am not sure if i hook up to same bat. or do i have to hook motor and tach to separet bat.? thank you.
Silvertip
e: how to wire twins into boat ?
It is recommended that you use separate batteries if the engines are fitted with charging systems. If they don't have charging systems, then you can use a single battery. Your boat would probably be as fast or faster with a single 50 than twin 25's since there is less drag. But since you have what is probably a cool looking boat, it is of no consequence.
