harringtondav
- May 26, 2018
- 2,473
Alpha 2 Coupler yoke from my pal's Rinker. The splines are twisted at the aft edge of the coupler. Bright wear mark - thinking coupler nose contact. Galling wear mark in the location of the gimbal brg shaft seal. Jet black gimbal bearing surface.
Cliff's notes:
2016 Replaced gimbal brg and leaking DS bellows. We dropped the front mount height from mid stud to bottom. No go on the alignment tool, but he wanted to go boating, so we forced the drive home.
2017 Another bad gimbal brg. (anyone surprised?) He had a shop pull the drive, install a new brg and check alignment. Supposedly the tool slid right in. Pal looks at the shaft & notices twisted splines. I take his drive to my place and R&R the shaft. I urge him to buy an new coupler and I'd help replace it. We did. He noticed transom rot at the bottom of the transom plate while installing rear engine mount bolts. By then I knew his alignment was still bad. I don't know what that dealer tech was using for an alignment tool.
2018 early. Out comes his 350 mag again. Off to the glass shop for transom repair. Reinstall the engine, and guess what? Front mount adjusters are back up to mid stud and the alignment tool was happy.
Summary: Many sages on this forum point to transom condition when there's an alignment complaint. I now know why.
But I can't figure how that shaft became twisted.
Cliff's notes:
