Just put the new axle and springs on my tandem axle boat trailer. I have never repacked bearings so do not know how tight to tighten the castle nut. So I put the hub on and hand tightened the castle nut and spun the hub for a while. Unscrewed the nut and retightened it several times to get the bearings set in. Even with the nut hand tight it was hard to turn the hub by hand (would not spin freely). Then I took pliers and tightened it to the next void to get the cotter key in. So they are basically a little more than hand tight. Took it out for a 10 mile test trip and the hubs were a little warmer then the back axel. One was 79 degrees and one was 87 while the back ones where 72 degrees. Is this normal or is something wrong?
