Hull Damage (Minor)
OklaState19
Hello Hello,
You all were so helpful with my previous question that I will start asking a lot more!
On the underside of my hull I noticed quite a bit of scratching and even a couple spots that were chipped with metal showing. Or it looks like metal.
Can you give me some advice, should I be worried? Should I still take it out this weekend and just plan to buy a gelcoat repair kit next week?
I have attached two images of the underside.
-Jeff
2008 Sea Ray 185 Sport
tpenfield
Re: Hull Damage (Minor)
Yes, I can give you some advice. No, you should not be worried.
It would be better to apply the gel coat fix before you go out for the weekend. Not sure if you will have enough time tonight.
But, yes it looks patchable with a repair kit. At least do the 2 holes, that is the fiberglass you are seeing underneath the gelcoat. the other scrathes can wait until the off season. Those are more laober intesive to fix. ( I hate it when those happen)
