Hull Damage
Nussbaum
I have a 356 Carver that I struck the sandy bottom of Sandusky bay, while traveling at 22 MPH. I now have cracks in the hull that go through in some places all the laminate layers. Other areas are not as bad. At what point is it not repairable?
arks
Re: Hull Damage
I'd suggest that a marine surveyor assess the extent of the damage and determine what needs to be repaired. There could easily be extensive damage that's not readily apparent.
Assuming you have hull insurance- swallow your pride, contact your agent and let them handle it. It's their business.
Re: Hull Damage
Ayuh,... When the Co$t of repair exceeds the precieved Value of the hull...
