Hull ID # on 75 Cheeta boat
Days away
I have a 1975 Cheeta boat and I cant find the Hull ID numbers does anyone know where there are stamped in the hull and is there two spot's where these number's could be found.Thank you,Sherman
Re: Hull ID # on 75 Cheeta boat
Ayuh,... On the upper starboard corner of the transom is the only place I know of, where they'd be found...
ziggy
agree w/bondo. upper starboard side on the transom is normal. but they can be other places too. seen me a newer pontoon boat at last years boat show that had it on the deck rail on the starboard side, just in ft. of the transom. was standing there talking to the dnr man and he mentioned he couldn't find the number on that perticular boat. i found it for him. inadvertently looked at the side..
also my hin is located dead center of the transom, just above the drive.
so there are exceptions to the most common location. i'd look the transom over real close + look at the sides, just in ft. of the transom. a 75 should have a hin. obviously, mine is a 75 too...
Days away
I was all over the transom and all over the rear starboard and port with no avail.
Is there any other Ideas out there.:confused:
The boat does not appear to have had any fiberglass work done to it.
