I have a 20ft Cathedral hulled boat that used to have an inboard engine with shaft drive.It was then turned into an outboard,but i dont think the prvious owners got a very good job done.I am getting a huge ammount of splashing from the outboard engine and by looking at it whils on plane,it seems that the tunel that was in the hull to give waterflow for the shaft drive should have been filled in,as all it seems to achieve now,is to throw water up against the leg of the outboard,causing loads of drag and even throwing some water over the transom.<br /><br />How would you suggest i go about filling in the tunnel,what materials,and procedure would you use,the hull is fibreglass.<br /><br />The tunnel is about 20 inches long and approx 8 inches deep and approx 10 inches wide.so is quite a big hole to fill in,and whatever i use,i dont want it breaking away and hitting the prop.
