humminbird 200dx quit working
miichael18
I have a humminbird 200dx and it quit picking up fish. The depth and temp works fine but it no longer shows any fish. I put another 200dx on and its the same way. It must be the transducer or maybe it just needs moved around? I bought the boat with it on there and it use to show fish. I tried cleaning the bottom of the transducer with soap and water thought maybe it was dirty. Could it be a bad transducer causing it to not pick up fish but still read depth accurate? or what could it be
Silvertip
Re: humminbird 200dx quit working
Did you perhaps change settings so that it shows "sonar arches" instead of fish symbols (if it has that capability).
rickdb1boat
The 200DX has the option to turn off the fish ID. I had one...
From the Manual:
Fish ID. There are three selections available: Off, ID+ ON, and
Adjust. The factory setting is ID+ On. With Fish ID Off, sonar
returns are displayed as “raw” information. There is no
interpretation made by the unit. Selecting ID Off also disables the
fish alarm.
ID+ On enables the 200DX to interpret the raw sonar data, and
using a variety of techniques, depict appropriate target returns as
one of three different size fish symbols. Further identification
shows whether the fish is in the wide or narrow beam. The 200DX
also displays the depth beneath the surface with the corresponding
fish symbol.
Selecting Adjust and making incremental changes enhances the
fishfinder’s ability to identify sonar returns as fish symbols.
Increasing the value to a number greater than zero shows more
fish symbols on-screen. In this case smaller sonar returns will be
depicted as fish symbols. This is useful for identifying many smaller
sonar returns (suck as baitfish) as fish symbols.
Decreasing the value to a number less than zero shows fewer fish symbols on-screen.
In this case smaller sonar returns are disregarded. This is useful for eliminating many
small sonar returns when seeking larger species of fish.
The 200DX remembers this selection even when the unit is powered off.
http://www.humminbird.com/images/PDF/200dx.pdf ] 200DX Manual[/url]
