rolmops
- Feb 24, 2002
- 5,519
I finally hooked up my 575 and started using it.
I do have a problem (apart from needing a splash guard) and that is that when the screen is divided in the top half and 2 bottom quarters,what they call "the classic layout",the bottom quarters have no reading whatsoever.It is as if the 200 kHz and the 83 kHz work fine but the 455 kHz is just non existent.
Is this something that is caused by the setting or do I have some sort of mechanical failure?When I use the simulator everything is dandy.
As always,thank you for your answers and opinions.
