Humminbird 998
The other day my normal sonar and depth went out on my Humminbird 998, the Side scan and Down scan still work fine. Any idea what could cause this?
UncleWillie
The transducer contains multiple elements at various frequencies and orientations.
It sounds like the 83khz element is non-functional.
That could be caused by a problem with the drivers in the Sonar display Head, A cabling issue, or a Transducer problem.
I would start with pulling all the connectors apart, Inspect for any corrosion and try it again.
