Re: Humminbird legend 2000
I have had two , the first one had a problem and I returned it to the factory and they replaced it.It has excellant definition , I can fish a <br />small jig directly under the transducer and actually get a return off the jig , you can literally watch the lure as you jig it up and down. I like the speed knobs pretty well. Now the bad points , The screen is diffucult to see in bright sunlight , the screen is not back lit<br />and the light it is equipped with is rather dim.<br /> The wire connection system is not very handy<br />for quick removal unless you leave off the factory locking device , the mount is ok except<br />you have to completely remove the knob on one side. It will mark fish and structure well.
