Humminbird Matrix - Garmin Etrex Handheld Connection?
johnjsa
Anyone hooked up a Garmin Etrex handheld to a Humminbird Matrix, I need help. I have a Matrix 15 & a Garmin Etrex Legend & have done everything the book said to do, but the Matrix does not recognize the Garmin handheld? Any suggestions? Thanks.
Greenwing
Re: Humminbird Matrix - Garmin Etrex Handheld Connection?
You will have to make sure your GPS is on the NMEA setting you will find this in the set-up menu and go to the interface tab. Check your manual I am refering to the way a Garmin 76 is. I had the same problem when I hooked mine up to a Matrix 17.
CntrySngr
Do you have to have a special cable to do this? I am considering a Garmin GPSMAP 60C and one of the Matrix finders.<br /><br />I am also considering a iFinder, but I none of them seem to be NMEA compatible.
johnjsa
I got mine working. I had to download software updates for my Matrix 15 & hooked it up & it works. I bought the cable from Humminbird, I believe it is ASGHHAR205. You can go to Humminbird's site & see what cable you would need. This one has a power supply, so my Etrex won't run down & plugs directly into the port on the Etrex.
