Recently purchased a boat that came with an old Hummingbird 300tx depth finder. When I power it up I get the initial logo screen, and then a "transducer not connected" message. I have checked all of the connections and they appear fine. The only thing I have came across was that hummingbird uses the water temperature pin from the transducer to detect if the transducer is connected. To remedy this you hit the menu button right when you power on the unit and from there you take it out of simulation mode. I had tried that with my unit and hitting menu right at start-up did not do anything. However, mine does not jump straight into the simulation. I have menu options and it appears to not go straight into simulation mode but I could be wrong.
The guy I purchased the boat from had never used the depth finder (He bought it at an auction, fixed it up and flipped it). Does any body have any potential fixes/advice?
It is possible that the transducer is shot, I just dont know how to tell.
Thanks
Thanks
