Re: hundreds of bubbles
[h=3]
Should I buy a boat with hull blisters?[/h]
I'd suggest you use the search function at the top of EVER forum page (in the blue banner) and search for:
Gelcoat blisters
It's an often discussed topic & there are LOTS of gelcoat blister threads. Look for Ondarvr's posts, he's our resident fiberglass & gelcoat expert & often weighs in on the gelcoat blister thread questions.
It is usually NOT a straight forward sand off the blister, fill the damage, feather the edges & recoat and you're done. Even small infrequent blisters will end up being a continous maintenance problem. Grind & fix 15% of the hull w/ damage this winter, more 'new' blisters next season, grind & fix them (another 15-20%) next winter, and when you pull the boat at the end of the season, more blisters. And repeat..................
Do some research on google using the same search terms: Gelcoat blisters
LOTS of info here @iboats & online
I'd avoid a boat w/ HUNDREDS of bubbles unless you want to completely grind off ALL the gelcoat, confirm there are no more underlying fiberglass problems, then start rebuilding the gelcoat, filling & fairing etc............. That's a heck of a lot of work, not inexpensive to 'repair' and extremely time consuming to be done right. A 2006 21ft Stingray needing that amount of work had better be extremely low priced. Plus be the 1 & only boat you've ever wanted.
Best of luck
