Any guidence would be most appreciated.......
We are turning the garage into 2 bedrooms, and then turning our deck into a sunroom........
Current house is 860sqft with basement
Adding 240sq ft of Garage as 2 rooms South with Shade
adding 240 sq ft Deck into 1 room, West, no Shade
I'm going to guess that the current system will not be big enough and will ahve to be upgraded, but I need to run the ductwork now before we close up the floor.
2.5ton AC unit ..don't know about the heat.
I will be gowing from the basement directly into the floor space of the garage, where I will deck it up to be the same height as the rest of the house.
I'd like to be able to run in 1 Vent/ Retun duct and split into each room...
What size do they need to be? I'm hoping to run felxible insulated duct.
Can I do like the rest of the house and use a stud space as the return in each room?
Trying to do as much on my own without calling in a pro. If heat/air system needs to be upgraded, I won't be doing that myself.
