IOmmSocket
- May 17, 2020
- 16
Hello, first post. I'll introduce myself : I'm Jake. I own an auto repair shop, been an ASE master tech for 15+ years. Just getting into boating - and I like an arduous project. I have had a couple of boat "projects" into and out of my life that I didn't really get wet with. I just picked up a 1990 Sea Ray 200 overnighter with a 4.3/alpha 1.
The engine in the boat turned over, wouldn't fire, and when I opened the block drain valve (was still "winterized") it was full of water. The oil was also full of water. I went no further knowing there was a significant failure and decided the boat needed a full engine refresh. Because I like to get in over my head and figure out the best way out while under fire I went ahead and bought a vortec 4.3 from a 2001 silverado and tore it down, discarded basically everything besides the block and heads. I brought those to my local marine machinist and had the block bored .020, crank and cam holes align bored, heads smoothed, and a couple of faulty valves replaced.
I've got the engine in my shop on a stand for assembly now, thinking I would just throw the cam from the 1990 engine into the vortec and it'd be a marine vortec - oops. The camshaft is very clearly different from the vortec - looks like much more duration with less lift, both are rollers. I've looked all over the internet in every place but the right one for good specs on the 1990 marine camshaft, the 2001 truck camshaft, and any vortec specific marine 4.3 camshaft and have come up dry.
First question in this whole series of fun is where can I find specs for these camshafts? I'd have to assume a truck cam would have low end torque a boat would want, and being stock I couldn't imagine it would have too much overlap - then again this was an EGR motor so it may. The other problem I'd have with the truck cam is loss of potential - does the truck make a lot less HP than a comparable boat and is this directly pertaining to the cam?
