mr300z87
- Sep 15, 2010
- 701
Since the weather in NJ has been so nice I have started my pre boating season maintenance including checking a re packing the trailer bearings. All was going well until I got to the right side brake axle where I found a leaking wheel cylinder. I figured no big deal went to my local part dealer and got what looks like a standard 10" or 12" wheel cylinder like this http://www.etrailer.com/Accessories-and-Parts/Titan/T0977600.html . This is like the system I am working with http://www.etrailer.com/Trailer-Brakes/Titan/T4071500.html
So here is where I ran in to trouble. Installed the new cylinder (it matched the old one) re packed bearings installed new seal cleaned brakes and went to install the drum. Once I snug up the nut the drum is spins very very stiff forward (can barely spin it the wheel) I can feel the brake dragging. I figured this could not be right took it apart and re assembled like 10 time adjusted all the way in still no luck I even swapped the original push rod. Stared at it and said a lot of bad words
. This made me feel better but did not help. LOL. It does seem to spin freely in reverse. This is the first trailer I have owned with brakes but have worked on drum systems before.Could the new cylinder be slightly longer than the old one which is not allowing the forward shoe to retract far enough. I have not bled the system yet but do not think that is going to make a difference. Any advice is greatly appreciated. Mike
