hydraulic fluid trim top up omc
tony123
i have a bayliner and the hydraulic trim has stopped working,the eletric motor runs but <br />it will not lift the stern or drop it .<br />im guessing its due to hydraulic fluid.<br />it looks like a corbra hydraulic unit.<br />but i can not see how you check the fluid <br />or change it .there is a screw on the side <br />is this it ?<br />please help
JB
Re: hydraulic fluid trim top up omc
This is not an outboard, Tony. It is an I/O.<br /><br />Moving to I/Os
CharlesW
My 1993 Chris Craft OMC has a plug on the side if the pump cylinder that is for checking the level.<br /> My owners manual says to be sure to have the outdrive in the full up position before checking the fluid!!!!
