Hydraulic Steering Pump Identification
jtspeaks
Hello all,
The front seal is leaking on this hydro steering pump. I have it apart and ready to install new seals, just need help identifying the pump so I know where to look for the seal. There is a metal tape attached (see photo) where the information was at one time, but it is long ago wore off the tape. The only numbers I can find are stamped on the aluminum block at the back.
This came off a Lurh 24 ft cabin cruiser I am restoring, and I would like to replace the seal, rather than spend $800 on a new pump. it worked great, just has the leak at the front shaft seal.
Can anyone help ID the pump?
Thanks
alldodge
Unable to say for sure, I would suggest calling SeaStar and ask for assistance unless someone here can recognize it
Contact Number: 604-248-3858
Hours of Operation: Monday – Friday 7:00 am – 3:30 pm PST
K-2
If no one can ID it, take the seal to a bearing/seal store, do you have BEARINGS INC. stores in your area .
