Hydraulic trim tilt hose fittings
Lancer76
I have a 1976 Mercruiser 233 with the MC-1 outdrive. The high pressure trim tilt hose from the pump to the outdrive manifold burst. I have some good hoses and manifold from a different boat (the new hose) but i see that the flare fittings on the new hoae are bigger than the original hose ( see picture). I don't know the fitting sizes other than i used a 3/8 wrench on the original fitting and a 7/16 on the new question is whether I can buy a fitting reducer to go from the larger new hose to the smaller diameter fitting at the reverse lock and the pump.
kenny nunez
On that early model all high pressure hoses are 3/16” inverted flare. With the exception of the low pressure plastic line from the reverse lock valve.
Lancer76
So an inverted flare reducer may work. I will check tomorrow. Thank you.
fishrdan
I swapped out a newer manifold and hoses (along with a new Oildyne pump) on my 73 Mercruiser and was able to get the reverse lock valve adapters from a local auto parts store, good auto parts store, Napa/Advanced, not Orielly/Autozone/etc.
I did away with the cheap leaky nylon hose and ferrule compression fittings from the trim cylinder to the pump, and used a crimped hose like you have in the pics... No-mo leaks!
TurtleTamer
Just went through something similar when switching trim pumps (Oildyne plastic-reservoir to a similar Oildyne). My pressure hoses, which I assume are not original to the boat, are 7/16-24 thread. The new-to-me pump has 3/8-20 thread and came with adapters, but the high side adapter broke. Took a lot of messing around at the hardware store and then Napa but I was able to find out those were the thread counts. Then I was able to make an adapter with a short adapter piece and coupler for the 7/16-24 side. The exterior hoses on the gimbal housing/rams are a different animal. I do not know the thread count but in order to plug the transom holes for bleeding I found that the shifter bolts for a 1993-1997 GM F-body Berg-Warner T56 thread in nicely.
