jam39vw995
- Sep 7, 2003
- 105
Hi.<br /><br />Thanks Bondo for the flare wrench size, it was a 3/8. This is a merc 165 and it's newer than I thought so it's probably an alpha drive.<br />Well, I attempted to get the hydros working today but didn't succeed.<br />I bled the system as per the shop manual. The leg goes up great but down it goes about 1/2 way and then the pump increases in speed and it stops. I cycled the leg many many times, adding oil each time but I still had to push the leg down for the last 1/2.<br />I'm pretty sure I had one of the lines on backwards on one of the rams and I corrected that, then things seeemed to improve except trying to get the leg down.<br /><br />Any ideas what would be causing the leg to go up well and then only 1/2 way down well, then stop?<br /><br />Thanks<br /><br />Jeff
