No over here we still have2 and 3 cyl 2 strokes in the portable to mid range, sometimes higher.
A hydro tilt assist is simply a hydraulic jack in the back of the engine, you engage and disengage it via its lever. Down locks it, up lets you lower or raise it. So saw you want to shallow water drive in a few feet of water you can lift it and lock it and shallow water drive.
Because 40hp and up are quite heavy the hydro assist (thats yamahas name for it) is really a necessity to do anything quickly.
The problem is my lever has just gone slack, like its all wobbly and feels like its broken away from the engagement. I think it has a lock nut, perhaps that broke. I dont think there are any issues with the fluid levels or the hydro system, because its locked in down position and all has been serviced recently.
Im going to access the manual release screw later so I can lift the leg and see if I can get to the hydro assist lever itself to see if its simply wobbling about because its snapped or disengaged due to a connector screw breaking. I hope thats what it is.
Was just hoping someone on here might have experienced it?
