i have a 1979 mercruiser inboard. i need to know where to fill the hydrolic oil for the trim on the outdrive. any help would be appreciated. thank you.
ok go to this link below and you should see the tilt trim motor for your boat as the top left picture this should be on the left hand side of your motor (if you have a 4cyl merc engine) and on one corner it will say "FILL" next to a flat head screw. just fill it up to the second thread from the bottem. move the outdrive up and down a bit then make sure it's still full and you'll be good to go<br /><br /> http://www.basicpower.com/026.htm
