Just spent a great weekend on Lake Powell with a friend. His boat (1987 Bayliner 2555<br /> with 260 OMC) developed a hydrolock (water in the cylinders) after sitting on the beach<br /> in a well protected cove, engine idling, his wife taking a shower with a lake water<br /> shower that draws hot water from the engine block drain, cold water from the raw<br /> water hose going to the thermostat housing, routed though a mixer, a pump, and finally<br /> a showerhead. My boat (Bayliner 3255 with same motors)has the same setup, with<br /> never any problems. He's used the shower before, but only once. After shutting it<br /> down, it wouldn't turn over later in the day. We pulled a plug, and there was the water<br /> in the cylinder. We pumped out all of the cylinders (after towing it in and putting it on a<br /> trailer), put in new plugs, and started it up. It took awhile, but it finally ran fine. He has<br /> had a noise which sounds either like a rocker noise or an exhaust leak for some time,<br /> but I don't know if it is related. Anybody got any ideas?<br /> Thanks,<br /> Steve
