Will need to know which CC is the smaller, which CC is the larger one to compare. If the smaller planes at 3/4 throttle the larger will do so at less throttle. Will achieve a faster hole shot, wot plane with a larger HP engine, providing that boat is perfectly deck weight ballanced, engine and prop are 100% operational. Once on plane can throttle back to cruising speed to achieve less fuel cosumption and extend your boating range than going full wot all the timne.
Sometimes when getting out of the hole with bit underpowered engine is much better to throtle to medium throttle, let engine rev up nicely to that point and then go full grip, Call it a 2 stage wot plane procedure. Underpowered engine generally loses some seconds to catch fast rpm from idle to wot,
Happy Boatting
