I am have problems with installation remote control tohatsu 40 tldi
Phol
I am not sure the remote control of the motor carburetor can be used with the tldi machine or not.
Because I saw that there are 2 plugs and 3
thank you.
pvanv
What is your actual model of motor, and which control do you want to use? Probably need the RC5F,
3GFQ845001RC BOX, RC5F, ALL TLDI/MFS40/50A$683.05
pvanv
Looks like the wrong control box. This is the one you need. Note that there are two connectors at the motor end, plus the tilt wires.Click image for larger version  Name:	002-21024-4_RC5F_FIG03.JPG Views:	1 Size:	81.1 KB ID:	10738921
pvanv
Yes, but not cheap.
3T5761151MCORD ASSY B (L=6200MM)$367.80
pvanv
However, that is less than buying a whole new box:
Phol
You thank vary much​ paul
I have a question.
I followed everything for purge the air but can not purge the air.
pvanv
Did you open the bleed screw and let the oil flow out through the oil filter?
Phol
this yes or not. If yes. Yes i do.
pvanv
When you open the bleed, if the oil tank is full, the oil will push the air out.
Phol
I have​ a bracket remote control cable but not use because​ wrong​ part, please​ tell me how many part and what any part number for install remote cantrol.
​​​​​​Thank you for your kind support
pvanv
If I understand your grammar, yes. Check page 41 of your owners manual.
