I am looking for a used replacement engine for my 120hp Merc
Jermaweld
I have been looking for a replacement engine for my locked up 120hp mercruiser in my 1969 starcraft trihull, I have found a 170hp on local craigslist and I am curious if it will bolt in or not. But if I can get it cheap enough is it economical to do the swap and how hard will it be?
thanks for any help in advance,
Jermaweld
achris
More fish than mountain goat
Re: I am looking for a used replacement engine for my 120hp Merc
Hello Jermaweld, and :welcome: to iBoats....
Be very careful, that 170hp engine is likely to be the much despised '470' (4 cyl, 170hp).... Don't walk, run, away....
The best option for you is a 3.0l, 140hp... Plenty around, not too expensive, and way less dramas than a 470..
Chris......
thumpar
The 170 is likely a 470 like achris posted. It will not just bolt in. The drive ratio will be wrong also. Look for the 140/3.0l engine. The externals are the same and it will bolt up without having to change the drive ratio.
Jermaweld
Thank you for your inputs, and I believe I will pass on the 170 and hold out for a 3.0L.
Ayuh,.... Wise decision,.... 'n Welcome Aboard,....
