Re: I am trying to figure this out...Help?
Thanks! So the next problem and hopefully a solution. When I notice the engine lifting in the front I was out on the water doing a test run (project boat). When the engine lifted, I thought the engine was not mounted down in the front when I got back to the house the engine looked like it was "loose". The bolts were not all the in. So went to tighten them and the wood that they mount to is rotted. I have since removed the engine and drive, cut the fiberglass that is over the wood and removed one wood mount.
Here is he plan; the stingers are solid so what I am suggesting is build a motor mount out of 1/4 plate and attach it to the stinger (see attachment). Now I am thinking the stinger is a 2X4, can I or should I drill all the way through the stinger and hull and run grade 8 bolts through or should I use 1.5" lag bolts to attach it? I think the 1.5" lags (6-8 on each stringer) would work but I just do not want ever do this again. Also I planning on fiber glassing studs in the floor to attach to. This is quite a bit stronget than the originals which were 1X4 brad nailed together. Any thoughts on this? Thanks again Paul
