I believe I'm right about this, but opinions are appreciated.
itsaboattime
I have a 1982 Four Winns Marquis 160 F&S (1100 lbs?) with an '87 Evinrude 110 hanging off the back. The rated WOT for that motor I believe is 5500 RPM. The motor has a 13 3/8 X 17, 3 blade aluminum prop on it and if I push the throttle all the way I can turn 6200 rpm.
Here is my Question, if I put a 14 X 19, 3 blade, aluminum prop on my 110, it will bring the RPM down to close to the rated rpm and give me some more speed right?
I understand my hole shot may suffer and it may take a lil longer to reach plane. I believe the prop that is on it is original. And I would be looking at replacing it with a Michigan Wheel 14 X 19.
tpenfield
Re: I believe I'm right about this, but opinions are appreciated.
larger diameter and larger pitch will get you headed downward in RPM . . . may get you below 5500 though . . .
itsaboattime
Yeah I was kinda worried about that.
SkiDad
i think you are right - i think that will put you about 5600 rpm - or close enough to the 5500 - i say even it you get down to 5400 you are good or 5600 you are good and leave it.
