I can hear the gears turning in the lower unit?
egleas84
I replaced my prop today and when I was turning it clockwise by hand (out of gear) I noticed I can hear the gears turning in the lower unit. I wouldn't call if loud, just enough to catch my attention.
Is this common or should I shop for a new lower unit?
See sig for specifics.
Re: I can hear the gears turning in the lower unit?
Ayuh,... Hard ta say, as in neutral, only the propshaft turns, 'n the 2 gears on it, aren't engaged to any other gears...
egleas84
Sounds like it's right at the bottom where the prop shaft meets the vertical shaft that goes up to the top of the outdrive. Yes, in nuetral. Haven't had any issues shifting.
Ayuh,... If ya didn't find metal in the drained oil,...
Fill it up, 'n Run it...
egleas84
Good call. Running with that advice.
egleas84
