1986Thundercraft
- Jun 23, 2021
- 1
Hi, thank you for reading this post. I need urgent help. I was on a lake the other day and suddenly lost gear. I was able to get out of the lake and I worked on it to get into one of the gears. I was playing around with the black plastic adjustment screw which only allows me to put into one of the gears, not both. I couldn't never find the middle where it allows me to put into both gears.
I replaced the cable thinking that it's cable issue, but no, it isn't. I really am lost what to do with it now. I feel like it's such a simple fix.
I can put into gear by hand by manually pushing far enough to be in gear. But with shift lever alone, it doesn't push or pull far enough to put into gear. Any advice is appreciated. Thank you!!
Video for Gear Shifting Problem
