OK... Hello everyone,
Here is the issue: I have a Mercruiser 3.0 with an Alpha One outdrive on a 1998 Stingray 190RS. I can run WOT with out any issues but intermittently when I bring the throttle back to neutral I blow the 10A ignition fuse. I went through the whole adjustment for the shift cable and interrupt switch and all seemed well. (I thought that it was the problem initially but now I'm not so sure).
I was checking all of the wiring today and when I was looking through the schematics I noticed that the purple wire seems to be the main wire on the engine that keeps the boat running.
I also noticed that my purple wire was short to ground. Maybe this is why it is blowing the fuse? I started disconnecting everything that is connected to purple to try to isolate the ground and it seems that the only thing to disconnect the purple from ground is removing it from the electric choke.
Now I am not sure but is it normal for the purple to have a short reading to ground with the choke connected? I'm at a loss here. I only have 189 hours on the boat and this is the first real issue that I've had. I don't want to take it to a marina and pay for a bunch of experiments! I'm an electronics tech for the Coast Guard so I know my way around wiring if any of you would be able to help me figure out why this fuse is blowing...
Thanks in advance,
Paul
Thanks in advance,
Paul
