I cut too deep!
Plan "B"
I am taking out all the (wet & rotten) foam and wood in my 83 Sea Ray Seville. While cuting out the floor I cut to deep with a jig saw and made a 6" long cut through the hull. I have read alot about hull repairs and see that you should repair the outside and inside of the hull. In this case because the fiberglass was cut (about a 1/16" wide 6" long") and not smashed or cracked, can I fill the cut with peanut butter and then lay up fiberglass over it from only the inside? I really don't want to grind out a bigger hole then fill it back in from the outside.
imported_rick
Re: I cut too deep!
After filling it with peanut butter from the inside, don't forget to coat the outside with gelly! :)
Bob_VT
Re: I cut too deep!
Welcome to iboats.......
OMG You cut your hull :eek: obviously ........ yes you can do it form one side but the gel coat repair will be necessary too.
You must have been distracted ;) we Vermont people rarely make those mistakes ........ well I did slice a trailer fender that way when using it to support a piece of wood!
oops!
Re: I cut too deep!
YOU CUT YOUR HULL ????....RIGHT THRU ?????:eek::eek:
your boat is toast....cant be saved.....bring it to me. :D
happens to every one.
fill with STRUCTURAL peanut butter (milled fibers and mini fibers) ....glass over from the inside with chopped and then at least 2 layers of `1708.
standard gellcoat repair form the out side.
BobsGlasstream
Re: I cut too deep!
oops! Re: I cut too deep!
I'll have you know that I didn't cut through my hull a single time during my restro.
I actually did it twice. :redface::p
Once above the water line, one below the waterline.:(
So don't feel to bad.
Bob
Tail_Gunner
Re: I cut too deep!
Thats the sheer beauty of fiberglass boats..Mended there as good if not better than knew..:cool:
oops!
Re: I cut too deep!
lol bob :eek:
i even cut one thru last summer while doing a transom removal for a coustomer....and i am supposed to be experienced :D
oops!
Re: I cut too deep!
its a glass boat......anything can be fixed !
Plan "B"
Re: I cut too deep!
Thanks for all the replys. I will fix her right up:). Restoring a boat in not as fun unless you cut through something you didn't want to:D.
Yacht Dr.
Re: I cut too deep!
Hello PlanB..
Welp.. leave it up to me to play devils advocate..
" I have read alot about hull repairs and see that you should repair the outside and inside of the hull. "
Could you...or Should you ... that is your choice..
If it were me..I would at least grind out and put a layer of mat and a few 1708s on the outside then gel repair.
Buts its me..and I seem to instigate some Heated threads here :) .
Trust me.. Im not saying this to get another heated debate on the subject..its really my belief and trade to do things the way I learned.
Tear or cut..Inside N' Out.. but I think you/we know this.
YD.
Jeep Man
Re: I cut too deep!
Just make sure to count your fingers after each cut.:D
Bob_VT
Re: I cut too deep!
Hello PlanB..
YD.
Yup....be careful of Yacht Dr........ he is an instigator :eek: and a GREAT resource for knowledge....... I will gladly yield on his fiberglass advice ;)
Get the repair done quick.....the leaf peeper's are a coming!!
