Re: I.D.Drive Serial No
That number is too old to look up by serial number alone. However, there may be a gear ratio stamped in the side of the drive in the same area as the serial number. The 470 should be running a 1.84:1 ratio.
Short of that, you can always pull the top cap and count the teeth on the upper gears. Should be 17 - 19
