I did it!
JB
Re: I did it!
I don't see any rod holders, Frank. :(
tater76
Re: I did it!
Is that the motor you built modeled after the 60hp? Lots of porting etc...? If so, hows it run out? I bet it could get real scary real quick LOL!
jerryjerry05
Re: I did it!
Looks like 2 jetskis glued together.
Great,how fast?
At first I thought you put the 150 on the other boat.
spool
Re: I did it!
Should have put the 150 on this dingy ;)
tazrig
Re: I did it!
I'd accelerate real slow if i were you...:lol::faint2:
Frank Acampora
Re: I did it!
OK GUYS! April Fool's Day! look closely at the photo. notice the cowl does not fit correctly? It is just sitting on the 55.
It would not be beyond reason to assume that I would hang an 85 on a little boat, but the extra 100 pounds over the 55 would just about put this hull under water at rest. I may be crazy, but I am not stupid. And even that is open to discussion.
The photo was taken right after I raised the transom to a full 5 inches over original. On that little Chrysler, this modification increased top speed by 3 MPH GPS.
Now I need to play with the prop and squeeze a little more HP out of the engine.
You can see another video of this boat at you tube. Mini Boat Racer with raised transom.
tater76
Re: I did it!
Now that's just wrong! getting our hopes up and all ;)
pnwboat
Re: I did it!
How about a picture of that camera mount set up on your head?
tazrig
Re: I did it!
Yah know... I'm kind of glad it's not real because I figured we wouldn't hear from Frank for a while and then he'd post saying things didn't go quite as well as he had hoped and....
