I fired-up my 1970 Chrysler 35HP this afternoon for it?s 2010 pre seasonal check-up. I have some concerns that I would appreciate some help with.
1. Changed the impeller that pumped since 1985, I?m not seeing a noticeable difference in the output (just above idle) but peace of mine?
2. Bubbles came from the bottom linkage side of my engine that d/n appear as exhaust from snout idling?
3. If I ground the wire connected to my thermostat, should my over-heating horn sound as a thermo test?
4. A fiber looking carburetor linkage/adjustment (last toward carb) appears split or does it come split?
Thanks In Advance,
JOW
Thanks In Advance,
JOW
Boat's Motor above Idling 9-25-08 with Cooling Water R.jpg72.5 KB · Views: 0
